Paul Mermelstein
Since buying my 2003 Beneteau 393 last November, we've had only a few occasions totake her out. Until this week, we have had no problems eitherunfurling or furling the main. Now, though, it gets very difficult todo both. I've read the posts on this site, but have not found asolution. Here are the symptoms:1. When furling, the main wrinkles horizontally as it goes in,causing some overlap of material. Doesn't start immediately, but getsworse as the main goes back into the mast. Again these wrinkles arehorizontal, so I tried tightening the halyard when the sail was out.No help there.2. I can, with difficulty (and using a winch), furl and unfurl whenat the dock with little wind. With wind, it is tough to do. With windpressure out in the water, almost impossible.3. Tried different boom angles, raising and lowering with the toppinglift. No joy.4. I always use back pressure on the furling line when hauling out onthe outhaul. Also use back pressure on the outhaul when furling.5. The car on the boom does move. Not slick, but it does not seem tostick.6. Looked at the furling line. Does not seem to be pinched in theroller. I don't think it has swelled in diameter, but that is just bylooking at it.So, any ideas would be welcome. Thanks much, folks.PaulPerseverance
