Furling lines
Aug 10, 2016
2
Macgregor 26M Wareham ma
Just sailed my newly purchased used 2011 26M for the first time. I previously owned a Hunter and a island packet and have lots of sailing experience. The boat handled extremely well in some pretty stiff winds and large waves in buzzards bay and I am very pleased with its capability. A big problem is the size of the furling lines for both the large jib and the boom furling main. They are string size and really hurt your hands and are hard to grip when trying to reef or just normal sheet tightening. I think I need to replace these lines but am worried the spool furler won't accommodate a larger diameter (not enough room). Has anyone replaced their lines with larger lines and if so how big.
Feb 20, 2011
8,059
It can be done by de-coring some or all of the section of line that winds onto the drum.
Jul 7, 2004
8,481
Hunter 30T Cheney, KS
I tried decoring line for my FF2 but it was still too much for the drum. :(
You might get some slightly larger line that will work if you decore it, but it might not be enough to make it worth it.
Pat
Jun 7, 2004
1,250
I've had WM de-core my last two furling lings and this has worked out in outstanding fashion....be sure and give them the boat size, etc. makes it much easier to furl the headsail in heavier winds. Pat
Joe
Jun 1, 2004
8,181
Instead of de coring.... purchase a 5/16 line and strip the cover off the core only section that will be inside the drum... that will leave the handled and cleated part full size.... the core will be 3/16.
You can also go the other way... purchase a 3/16 furling line and cover it with a 5/16 sheath. You will need to perform a "bury" splice.. or "taper" splice... to blend the cover into the core.... A very easy splice that requires minimum tools.
