Furling line stanchion blocks
Jul 7, 2004
8,480
Hunter 30T Cheney, KS
You might try Garhauer. I'm expecting 6 new rollers for my Hood "siamese" stanchion blocks today.
Apr 5, 2009
3,079
Is Tom the new Guido?
Possibly but I have always asked for Guido. Garhauer has never let me down. The traveler car on my C30 Mk2 started binding up and I called and he set me up with a piece of track and a bag full a ball bearings. Now it is smooth as butter. I also asked about increasing the purchase and they suggested adding a second block to the car which increased the purchase from 3:1 to 4:1. much nicer.
Likes: Sailfanatic
Aug 1, 2011
3,972
...and the upgrade kit increases that to 5:1, and moves all the parts into the same plane, on top of the car, instead of the twisting motion that this offset setup does. Makes it really useable.
Jul 7, 2004
8,480
Justin
Received new rollers from Mark at Garhauer
They should fit perfect
Thanks
Tom
Cool! They will. I don't know if it will make a difference, but I sprayed the pin and holes with McLube dry lubricant before I put then back together.
Apr 5, 2009
3,079
If your pins are scared from the old sheaves you can give them a bit of polish with fine emery cloth and some metal polish to let them turn easier.
  • Helpful
