We experienced a major jam on our Furlex (headsail furling system) yesterday in 10kts of wind, and light seas. The furling line jammed between the guide (internal plastic piece that helps build the lay of the line on the drum) and the housing. I could not free it and had to take the jib down to get back into the harbor. In the slip, we removed the sail, and partially disassembled the Furlex to free the jam. This is the second major jam on this system. My thoughts:1. Too much line on the drum - I could easily remove a dozen turns and still have "enough" - but how many wraps should I leave on there to help get things started?2. Wrong lead angle - The block that leads this line is approx centered on the Furlex openning (but mounted on the pulpit rail). I could lower it to try to keep the line from building at the top of the spool, but that might cause a larger buildup at the bottom of the spool.When freed (but without a sail installed, it spins freely. - Any similar experiences?
