furlex disassembly
3
- - swanzey n. h.
I own a 336 hunter with furlex furling, Need to replace the line. Have a picture of unit but it is not clear on disassembly. It looks like the two halfs of the spool may snap together, Also there is plastic ( Rivot ) ? in one of the two holes in the base of the spool. Do they need to be drilled out before the two halves can be unsnapped ? this is a type two class B furlex -------- j ----------------
C
Claude
Furlex
Jim, You might want to check this web site. They offer a PDF version (52 pages) on the Selden / Furlex Manual, including installation instructions, assembly manual and a lot of graphic information. Good luck
