Several years ago I replaced the bearings in the drum of my Hood Seafurl 810LD. Now the halyard swivel is frozen. Has anyone dealt with this problem? I'm wondering if I should attempt to replace the bearings or just buy a new swivel. The manual diagram shows four sets of bearings and looks pretty complicated. Plus, it appears to be a sealed unit as there are no screws holding it together.
Also, the research I've done on this site indicates that, to replace the swivel, you have to go up the mast and remove the halyard at the TOP. Couldn't I just unhook the halyard at the bottom, remove the furler drum and slide the swivel down and off the foil?
