Back Stay Tensioner Advantages
Roller fruling does not reduce the advantages you recieve from an adjustable backstay. Eventhough you are using a furler, the forestay tension still increases when the backstay is tightened. The depowered headsail that results provides improved pointing ability, speed, and control in a breeze. Initially on our 33.5 (also a fractional rig with furling), I was concerned that tensioning the backstay would bend the mast sufficiently to DECREASE forestay tension. This was NOT the case. Pulling the mast back provided the expected benefits to both main and head sails. Additionally, having the tensioner enabled us to tune the rig with less prebend in the mast, which allowed for better performance downwind when the backstay tensioner is eased. It seems that all furling units are sensitive to one thing or another. On the 33.5, the Hood 810 unit seemd more seinsitive to halyard tension than to forestay tension. At any rate, backing off of the halyard and/or the backstay tensioner when furling seems a minor inconvenience. Enjoy the new toy, RonFormer Captain of Counterpoint H33.5 (1989)
