Furl Jib
78
- - Oyster Bay, NY
When we furl our jib, we get what I call a “candy cane” spiral. Increasing tension or decrease on the jib sheets while furling doesn’t change the effect. Any ideas?
Nov 30, 2007
276
Hunter 36 Forked River, NJ
We might need some more information here. I assume you mean that when furled, the UV protection strip doesn't have the appearance of a solid color, but has a white spiral through it. Do you get the same effect when you furl with the sail to the port as well as starboard? I always seem to have an easier time, and cleaner furl when the genny is furled while partially filled and to the starboard side.
Sep 29, 2008
1,962
Catalina 310 #185 Quantico
I occasionally get that
It helps for me to have a little more tension, especially when I start furling the genoa. Kind of a pain, and for my next genoa I may get the sunbrella a little wider.
Oct 24, 2009
21
Catalina 310 Rochester, NY
I had the same thing happen to me. When I furled the sail , I didn't apply enough tension on the jib sheets to make a smaller diameter furled sail. Alittle extra tension solved my problem.
