Funky electronics!
Oct 26, 2008
6,375
Catalina 320 Barnegat, NJ
I have 3 Raymarine instrument displays that I have tried to re-purpose, unsuccessfully so far. They are the i50 Depth, i50 Speed and i60 Wind. I tried to include them in my NMEA 2000 network with all new B&G instruments and chartplotter. I fashioned a box to hold the displays over my nav station in the saloon and I used the cables that convert the port differences. The theory is that the instruments can be used as REPEATERS, not MASTERS, since the transducers are no longer connected directly to the instruments. The manuals provide a step-by-step procedure to convert the instruments to repeaters, if necessary (the instruments can adapt automatically, it seems).
The wind display converted automatically and has always worked as intended. When I first attempted to change the Depth display, I was able to get the display to read "MASTER" but it is supposed to blink so that you can change it manually to "REPEATER" using either one of the arrow keys. Same thing happened with the Speed instrument. I fussed with it for an hour without getting the result I was looking for.
Several days later, my buddy @Ward H was on the boat and I showed him what I was attempting to do and OMG the display showed a blinking "MASTER"! I don't know what I did differently to get there, but I switched it to "REPEATER" and sure enough I had an accurate depth reading! We did the same thing with the Speed instrument and it was already changed over to "REPEATER"! OH JOY! The only problem was that it wasn't reading the water temp and there were no speed readings for either boat speed or SOG. So apparently, there was something missing.
After Ward left, I turned electronics off and later I turned them back on. The Depth and Speed instruments reverted to "MASTER" and no matter how I tried, they could not be converted. It appears that Ward's magic was missing. :(
I think that Sue is not going to be happy with that box hanging over the desk with 3 displays so it's going to come down. I realize that I can get all the info I want inside the cabin by installing one B&G Triton display in a discrete location (wind & depth is all I really want while anchored). I'll just give up on the RM displays.
For just a little more money than a Triton2 display, I installed a Simrad 7" plotter. Connect it to the N2K network and to the main CP with ethernet and you get all the N2K information plus radar and AP control.
Oct 26, 2008
6,375
Fair point. I've already mounted my left-over Garmin CP (probably about the same 7" plotter size) near my radio. I use it to monitor anchor position & just keep it as an independent back-up. I could replace it with a 7" Vulcan so I wouldn't have to take more space on the panel.
The only reason I went with Simrad rather than B&G was the Simrad had a Rebate and was cheaper otherwise it would have been a Vulcan. Watch in the spring for sales and rebates.
Oct 26, 2008
6,375
Put one of these on the network and all of your data will be available anywhere on the boat via wifi to your phone/tablet/computer: A032 NMEA 2000/0183 Bi-directional Gateway + USB + WiFi
Nice to have the data on a phone next to the bed.
Mark
One of these what? My whole network is NMEA 2000 (I have nothing that is 0183 so that function isn't applicable). If I had this device, would I simply connect the NMEA 2000 cable to a port on the network? Then my phone would pick up a wifi signal (or connect USB)? Then what? Do I need an app to display data on my phone as if it is a Triton instrument? I'm pretty much illiterate without step by step instructions.
colemj
Jul 13, 2004
833
Yes, you just plug the unit into your NMEA2000 backbone via a Tee connector, and all of your NMEA2000 data will be available on wifi. You do need an app to display data. Many people have Navionics or Aquamap or similar apps that will accept and display the data. Otherwise, there are boat instrument apps that display the data. If you are only interested in an inside anchor alarm, there are anchor alarm apps that will use the position data.
I have Apple devices and use Navionics, TZiBoat, SeaIQ, Imray Instruments, NKE Display Pro, and Anchor Pro apps with it. Also OpenCPN on my computer and Android tablet. If you have Android, I'm sure there are equivalent apps for that available.
Setup involves only connecting to the device's wifi network, which shows up on your phone/tablet/computer wifi choices.
Like yours, our system is all NMEA2000. I just leave the NMEA0183 cord coiled up on the device. Also don't use the USB port, but both of those are nice things to have anyway.
Mark
  • Helpful
Likes: Ward H
Ward H
Nov 7, 2011
3,814
That gateway with WiFi sounds pretty slick. I have a couple spare iPads around and have Navionics on all of my devices.
Currently I mirror off of my Axiom CP but getting the data directly off of the network sounds like a better solution.
