Joe C.
Well folks, I sailed my 260 from Smith Point to Annapolis and back to attend the boat show. I thought that Annapolis was beautiful from the water. The show was great and we had some great sailing including a peak of 10.2 kts. surfing some big following seas on the way home. About 15 NM out of Smith Point Marina (pretty good place by the way) the boat rounded up and wouldn't come back. When I looked back to check my rudder position it wasn't there! I hung my head over the stern and saw that it was hanging by the up and down haul lines and trapped in between the transom and the outboard. We got the sails down, the rudder aboard and the motor started and made our way back. I'm sure glad that I had installed a steering link for the outboard. The bracket looks pretty rough, but the rudder is fine. The 1/2" bolt broke in two and is at the bottom of the Chesapeake. I had been holding the rudder down with the down haul line as Hunter suggests and I think most of you do. Any similar problems out there?Jeff Peltier please email me. I couldn't find you on the owner's list.I have talked to Greg at Hunter and emailed pictures aswell. I'll keep you posted as to what they say.We were on a broad reach about 15 deg. off of DDW with about 20 kt. winds and 3 ft seas with a 4ft wave now and then.I am also having problems with the outboard bracket bending as did Jim's on Java. Hunter told me that they sent him a replacement that was the same as the original. It is my belief that it will only bend the same way. The bracket needs to be stronger and taller. I didn't buy this boat to only lake sail on calm days. I am using it well within the "CE certification" conditions that we just had so much discussion about. These seem to be weak links on an otherwise pretty well made boat.Looking for construtive comments,Joe C. in NC'01 H260Windward Passage
