Hi all -
I had a tough time starting my Yanmar - YSM12 (one-cylinder) diesel this season. I didn't change the fuel filters (I have a water separator and another filter on the engine itself) but thought I would get to it later this season. So last weekend it would not crank over (first time starting for the season). Turns out both fuel filters were bone dry - lost its prime. Odd as for the last 6 years she always cranks over on the first or second try. I filled the filter and bleed the system - started right up (I ran it for 10 minutes but did not leave the dock). This weekend at the dock I ran it again for about 10 minutes to test it: started right up but then after 10 minutes it stalled when I revved it up. Both fuel filters were bone dry. I bled the system and it started right up.
So I assume my filters need to be replaced which is fine and I plan on doing so next week. I am curious as to why the fuel system would run dry though. Could it be my fuel pump or does it sound like filters are clogged? I pulled the tank out of the boat 6 years ago - drained / cleaned it out and have never had a fuel issue since. Perhaps after 6 yrs I have water in there or something else going on. The injector is only 6 yrs old. I have not noticed any diesel leaks in the fuel system.
I am wondering why the system went dry over the winter - that has never happened before. I store the boat up north in NY. I did have the exhaust manifold off over the winter being repaired but that would not have caused this.
I appreciate anyone's thoughts on this and if I missed anything other than the filters just needing a change.
- Rob
- Rob
