Full Battens
992
Oday 25 Gibraltar
I only have experience with standard battened mainsails and was wondering if there are any advantages with a full batten main. It seems like you won't be able to tell when the luft would be softening or when you were getting a bubble. Are they as sensitive to adjustments?
Rich
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Rich, you are correct. They do induce an artificial shape into the sail. In light air they are especially deceptive. The key is to adjust the tension on the batten and sometimes change to softer battens to match the wind conditions. In an ideal sail the batten tension should be adjustable just like all other sail controls. No one has yet come up with a good effective way to do this.
Aug 4, 2009
204
Oday 25 Olympia
IMHO a full battened main sail is the greatest thing since sliced bread. First and formost they are sail savers in that they eliminate flogging. Secondly they help shape an older sail into a useable driver. The battens can be shaved for fine tweeking just make sure the stiffest part is aft to flatten the leach area. I would not like to sail without them, at least in the upper half of the sail.
For what it's worth, Geohan
RichH
Feb 14, 2005
4,773
"It seems like you won't be able to tell when the luft would be softening or when you were getting a bubble" .... and thats why you use 'tell tales'. ;-)
Nov 20, 2007
27
Flying Scot and self built wooden dingy 19 foot and V12 WV and MD
I have a question about how long the battens should be - should they be long enough to actuall put a bend (curve) in the sail or just long enough to stiffen the sail? I had a sail once that the battens were so long that they forced the luff pockets into the mast making it hard to raise. I could tell this by seeing the scuff marks on the batten pockets - these were full length battens. - I don't have the boat any more but am interested in how tight they should fit.
Jan 24, 2008
293
Alerion Express 28 Oneida Lake, NY
Alan:
I'm intrigued by your comments about batten tension.
What tension are you referring to?
Thanks,
Paul
Dec 4, 2008
264
Other people's boats - Milford, CT
Paul,
When you insert a batten, there is typically a velcro strap that can be adjusted to push on the batten. This can be set light or heavy to work like an outhaul.
Alan,
I wonder if someone could run a pully operated system (like some mainsail leech lines ) that ran down the luff of the main. But it would probably be hard to keep constant, since luff tension would effect it. Maybe electric stepper motors :)
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Todd, actually I have been working on just such an idea. As you say there are plenty of issues to address. I do run my leach line over the top and down the luff. In so doing I can control the leach tension from any point of sail. Specifically on a broad reach or run the traditional leach line placement makes this impossible. With the leach line at the mast this adjustment can be made at any time.
