Adding Battens to an RF Main
Tony,Since your RF main is designed with leech hollow adding vertical battens to it would limit the benefit to preventing leech flutter and leech hook. I don't think that this is a bad idea since these mains typically have problems in this area. You need to make sure you have enough room for the battens to pass through the mast opening. I would recommend using 200 flat battens. While the sail is at the loft you should have them look at the leech to see if it needs any take-ups before any pockets are added.Thanks,Bill C.Doyle Sails
