I have a 10 hp 2 stroke dingy engine and a honda 2000 generator.
I carry gas in two 5 gallon jerry jugs. I move the gas to the fuel tanks with a squeeze bulb on a long fuel hose.
I'm thinking of adding a filter to the fuel hose to clean the fuel of dirt & water at the time of transfer.
1. Looking for suggestions on very small fuel/water separators.
2. Will I easily be able to push or pull gas thru the filter with my squeeze bulb setup?
3. How long can 2 stroke gas/oil mix sit in the dingy tank if the gas has ethanol, before more phase separation happens? I burn thru the little honda genset tank fairly quick. But my 9 gallon dingy tank can last a month.
Thnx
Thnx
