Fuel/water separator for an outboard?
1,517
Jboat J24 commack
I have never had and issue with a 3 or 6 gallon outboard tank
IF your do
I prefrer a real Racor outboard unit that has a clear bowl and a drain that will allow you to see the issue and do semething about it and it does have to be mounted correctly to work
1,096
CS 30 Toronto
Why border with fuel/water separator for a 6hp OB
First you don't use that much fuel anyway. Secondly you don't have a deck fill which will admit water if the "O" ring is cracked. The fuel tank is most likely portable so you can dump any expired fuel to municipal disposal and always have fresh fuel. There is usually a filter inside the OB that you should change once in a while.
RichH
Feb 14, 2005
4,773
Best solution is to get "recreational"/no-ethanol gasoline ..... then you dont get 'phase separation-dropout' of the water from the ethanol and forming a layer of water in the bottom of your tank upon 'long term storage'.
Such gasoline (90 octane) is usually found in areas that have a 'large' boating usage. You may have to search/seek such suppliers even in those areas that have such fuel.
In the SE, such 'ethanol-free' fuel for 'recreational use' is become more readily available.
Jan 27, 2008
3,086
ODay 35 Beaufort, NC
I'm not entirely sure of this but I think clear plastic bowls aren't allowed for gasoline, that may be only for inboard installations but in any event there is a high possibility of cracking the bowl causing a leak and a fire, all outboards I have seen with water separators on center consoles and such are similar to the link you have from my favorite store.
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
Some of the smaller outboards were not designed with an external fuel filter in mind so their fuel pump system may not be of adequate capacity to prevent fuel starvation at higher rpms. Sometimes a weakness which does not manifest itself when the filter is new will show up prematurely as sediments start to build up.
Jun 2, 2004
3,507
Yes
Our kids sailing prgram has several small boats with outboards and we installed them on all of them.
It must be held upright somehow, A better description of your proposed installation will get a better answer than that.
I would not get the Walmart one I'm sure it is aluminum or some chaep alloy and is going to corode. WM has a stainless steel one that works well in saltwater.
We had an issue with one where the seam of the canister rusted and started leaking then when I went to unscrew it it came apart I was not sure it was going to be able to get the rest off but I managed to.
I bought one for my boat last year when they were on sale but have not yeat installed it on my boat. I seem to spend all my time working on the club boats and ignoring mine.
Heard last week that the ethonal shrinks the plastic bowls on the Racor ones and they fall off. Don't know that for a fact just what I was told.
Dec 2, 1999
15,184
I suggest that you check your engine. It may already have a fuel filter under the cover. If you think you want another filter, put an in line one. They can be had in either plastic or metal. I don't think it makes any difference if it is plastic as long as it is NOT in the engine compartment (like an inboard).
You really don't have any specs on this filter, so you don't even know if it has the ability to filter or seperate the water. Like many things from Walmart you usually get what you pay for.
Jan 10, 2009
590
PDQ 32 Deale, MD
Where around the Chesapeake Bay?
best Solution Is To Get "recreational"/no-ethanol Gasoline ..... Then You Dont Get 'phase Separation-dropout' Of The Water From The Ethanol And Forming A Layer Of Water In The Bottom Of Your Tank Upon 'long Term Storage'.
Such Gasoline (90 Octane) Is Usually Found In Areas That Have A 'large' Boating Usage. You May Have To Search/seek Such Suppliers Even In Those Areas That Have Such Fuel.
In The Se, Such 'ethanol-free' Fuel For 'recreational Use' Is Become More Readily Available.
My sailboat has no problem, but the tender is trouble if I forget to close the vent when I am gone for a week.
Jan 10, 2009
590
PDQ 32 Deale, MD
Yes, Raycor makes clear bowl filters for gasoline.
If they shrink, it must take time. I have had some in service for 25 years. However, the smaller sizes can have corrosion issues (spin-on center unit) if exposed like that. Replace the element every 5 years and you will be fine.
As for the suction issue, the smallest sizes are for 100hp outboards; a 6hp will not create suction for a LONG time. However, if the element sees water it will swell and cut the flow. This is intentional, to prevent engine damage. Carry a spare.
I don't believe any of the Raycor stuff is SS; aluminum and painted CS. Tip: ALWAYS remove the filter before you put it on the boat, and then re-tighten. The factory generally tightens them WAY too much, and it is easy to break them later, once they have aged.
The difficulty with a plain spin-on (original post) is that you cannot drain the water... So what good is that? You need a drain, or just rely on the factory filter.
Jun 2, 2004
3,507
We Wanted to Keep the Globs out of the Carb
After we went through three carbs we put these on and it or all the other steps we have taken are working so far.
This is from the West Marine catalog description
Stainless-steel or aluminum Bracket and Filter Assemblies add fuel/water separating capability to any outboard, I/O or inboard. 21 micron filters with a high pleat count. More pleats means more capacity and greater efficiency. Kits include one 18-7845 (Mercury long style) or 18-7844 (Mercury short style) filter. Will not separate 2-cycle oil from gasoline. Not for use in diesel applications.
10 Micron Technology Prevents Ethanol-Related Damage and Performance Problems
  • Ethanol-blended fuels increase the chances of water in the fuel tank, robbing your fuel injection system of critical lubrication the fuel would otherwise provide
  • Gunk stirred up from ethanol fuels can clog fuel injectors
  • 10 Micron Technology removes over 99% of the water and over 90% of harmful contaminants. It guarantees proper lubrication and constant fuel flow for your fuel injection system
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
I use a small Racor 025a water/fuel separator filter on my boat, which is outboard powered. I installed it when I bought the boat and haven't had any fuel related issues with the outboard since then. It is mounted to the side of the outboard motor sled... and has a clear bowl that is easily checked before every outing.
Jan 27, 2008
3,086
What the heck is a 3 cycle engine? This is from the product description for the filter on the original post?? Maybe it is only for Wankel engines and they got a good buy on them?
Product Information
Fuel water seperator kit fits all 2 and 3 cycle engines. Filter and bracket included.
  • With double seal, universal 3/8" ports
  • Fits all 2 and 4 cycle engines
  • Filter and bracket included
  • Replaces Mercury 35-60494A4
  • Includes 2 brass plugs
Assembly Required: N Model No.:11840-7Shipping Weight (in pounds):2.1 Product in Inches (L x W x H):4.0 x 5.75 x 6.0 Assembled in Country of Origin:USA and/or ImportedOrigin of Components:USA and/or ImportedWal-Mart No.:004556580
