fuel usage on generator
John Van Stone
Does anyone know what the fuel flow on a Kohler 8KW diesel generator is?
Bryce
fuel usage
my mini 8 Panda uses about .2 gallons/hour. 2 cylinder Kyboto 3600 rpm. hope this helps Bryce S/v Spellbinder
Bill walton
.6 gph
Hard to say without a fuel flow meter but we've estimated between .5 and .75 gph on our Kohler 8Kw.
L
LOREN HALL
Varies with load.
I have a Northern Lights 6 KW on my Hunter 430. The fuel consumption varies a lot depending on the load. At very light loads it is about .2 gph. But when I'm running the AC and or watermaker , it will use .8gph.
Buck Harrison
Loren,
I have the same Northern Lights 6kw on my 420 and I have been guestimating .4-.5 gph..... but I haven't been loading it down completely BTW... slightly off the subject... I put an 18" 'Max-Prop' on in Oct. and it seems to have increased engine fuel consumption by about .2-.3 gph at 25-27k rpm. over what the (as delivered) fixed 3 bladed prop did
