Hi Larry
Check out the Beta 3 Cylinder 20hp (BD722). Fits
pretty well into the Vega and has that extra cylinder.
Cheers
Steve Birch
[AlbinVega]
Sent: Tuesday, June 10, 2014 6:49 AM
To:
AlbinVega@yahoogroups.com
Subject: Re: [AlbinVega] Fuel tanks:
Hi Walt,
I am looking at two different engines. The 2YM15C-14HP Yanmar and the 3YM20
22 HP Yanmar. I have been following Chuck on LeaLea and he has been mentioning
that he is under powered for the waters in Alaska. It sounds like the currents
must be pretty strong. And it looks like I will be heading up that way before to
long. This is one of the reasons I want to place my fuel tanks mid ship. Even if
I go with the 3YM20, I can place it 3 inches forward if needed I believe it is
27.2 in long as the 2YM15 is 24 .2 inches long. Everything else size wise is the
same. The weight of the 3YM20 is only 39 pounds heavier. A guy could leave 39
pounds of junk on the dock and be good. I live in the NW and we have a lot of
rivers and inlets up through BC. I know it is a sail boat, but from what I have
witnessed watching Chuck, he is running his engine a lot. If I could see how to
install the Yanmar stern drive unit I would get it. I have been looking at how
it could be mounted. Maybe in front of the rudder? Even if one had to relocate
the rudder aft a few inches? Maybe mounting the Yanmar stern drive right behind
the rudder…that won’t work, the shaft from the rudder would be in the way.
The time couldn’t be better to make any small adjustments for a power
plant than right now. I have my boat gutted clean and I have started at one
end of the boat and reinforced, re-glassed, repaired all stress cracks, old
holes for god knows what and making her stronger than new. And of cause keeping
the weight in mind on every move, so far very little added weight, and a great
tight boat.
Larry
Sent from Windows Mail
AlbinVega@yahoogroups.comSent: Monday,
June 9, 2014 8:47 AMTo:
Larry, What engine are you using? Walt
AlbinVega@yahoogroups.comTo:
AlbinVega@yahoogroups.comDate: Mon, 9
Jun 2014 05:18:17 +0000Subject: [AlbinVega] Fuel
tanks:
Good evening all,
Have any of you placed fuel tanks under the couches in the cabin? I am
thinking I could build two tanks, one on port and one on starboard, placed on
the bottom of the hull floor. The added weight would be mid ship, and sitting
off center of the keel. I thought of placing them under the cockpit, but
the weight is aft and could cause some problems. Thinking center of boat, added
weight, down low sounds good. Any thoughts?
Larry
