The diesel fuel tank sender on my 2000 H340 seems to have bit the dust. It was working fine at the start of the season but has gone completely dead. I cleaned the wire contacts on the sending unit but still get no reading from the gauge (with the ignition on). When I short the sending wires, the gauge reads full so the problem has to be the sender. The sending unit does not have any brand name but looks to be a standard 5 bolt unit. The bolts look to be threaded into the 30 Gal. polypropylene tank and there is a gasket. Does anyone have any experienced advice for replacing, sealing and calibrating a replacement unit?
