Don
A bottom seam on the 22 gal. aluminum is leaking. In looking for a replacement I can't find a tank that has a fuel return connection. The original Mfg. of the tank (Florida Marine Tanks) says that the fuel return is not a requirement, but will will install one at the customers request.Question: what happens on a 2GM if there is no fuel return line? Also any suggestions on a replacement tank.Thanks.s/v MerEllis
