Fuel Tank Questions
Bob Zanowicz
I was wondering if anyone used anything bigger than the standard(?) 3 1/2 gallon fuel tank for the Hunter23 (87 Wingkeel). I have at home, a 6 gallon tank not being used that might fit where this existing tank is used. My 9.9 sailmaster is a bit thirsty and I hate to having always check the fuel level, then mix oil and fuel and....you know the drill. To limit this with a bigger tank this would be great. Any thoughts? Bob
L
Lee
6 gallon tank ok
I have a 1988 model and use an Evenrude 15Hp. I use a six gallon tank. It fits in the compartment with zero room to spare. Because the compartment is slightly tapered, you could set it up a little on a couple of blocks of wood.
K
ken
6 gallon reply
How often would you need to fill up? even with the 3.5 gal.tank if it sets for a week or two the oil/gas will seperate. be sure you have enough roon to be able to shakeup the tank to remix oil/fuel. also keep in mind breakdown of stored fuel. if the tank is full and you let set an extended period you may want to add some fuel stabelizer. I carry a 1.5 gallon can and add to the 3.5 gal. tank as needed to top it off before heading out. good sailing.
dan miles
6 gal tank
I have a Honda 8 hp and put the 6 gal tank in the bottom of the boat at the stern thru the cockpit seat access. I made a small hole to down near calf height and ran the fuel line. This works great because it uses all that space down there you can't get to and it opens up the other space now to put something else for easy access, like a cooler of beer.
W
Ward
Fuel Tank Location
I have a six gallon safety tank and it fits nicely in the compartment on the starboard cockpit seat. Dan mentioned he located his in the bilge (under the cockpit). I will assume Dan took lots of precautions to reduce risks of spills, broken hoses, leakage, etc. The fact is... Gas fumes are extremely flammable They will settle in the bottom of the bilge There is ONLY 1/4 inch plywood separating the cabin from the bilge and it isn't airtight. One spark with a spill and you have a VERY powerful bomb I assume the battery is in the bilge as well. (eventual sparking capability) Dan, I apologize if you take offense with any of this. This is NOT pointed at you. I merely want to point out some of the inherent dangers of placing gas in that area. I also realize lots of people and manufactures do it. just my opinion
Bob Zanowicz
Thanks
Thanks for all the input. I am very leery also of putting a fuel tank in the bilge area per Ward's message. The previous owner used the 3.5 gallon tank up top and used a regular 5 gallon tank he would store down in the bilge area. I guess for some it might be OK but not for me. Bob
