I have a 1984 Hunter 31 I have been getting air in my fuel system. I started with new fuel lines then a new fuel pump. Checked filters installed a new fuel water separator filter and gasket. A mate then told me to check the fuel pick up. I removed it from the tank and it is an aluminum street elbow with an integrated hose barb under the threads. It has a hard plastic tube on it that appears to have been heated to originally install. Of course it is hard and brittle, it swivels around the barb very easily and could very well be where the little bit of air is coming from. Now the question I am looking at putting a 20" long Tygon hose on the barb, Yes I know I will have to fashion a clamp over that connection because over time the tube will swell and leak air once again. Then installing a brass fitting in the inlet end of the tube with a brass screen fashioned over the inlet side of the fitting. So the pick up tube can slide around the bottom of the tank. That being considered can anyone see why I shouldn't do this?
