Fuel Tank leak Oday 30
Jan 7, 2011
5,695
Oday 322 East Chicago, IN
What is it made out of?
My 1988 O’Day 322 has a poly fuel tank (as well as waste and potable water). Those tanks are pretty stout.
Have you identified the leak? Corroded through somewhere? Leaky fitting?
Greg
We had a leak in the tank of our 28 which is a pretty similar boat. In our case there was a copper bonding wire running under the tank that touched it in one place, causing some dissimilar metal corrosion. We had a new tank fabricated and replaced it. To get the old tank out we had to cut the fill neck off. We had the new tank made a couple gallons less tall to be able to fit it in.
