Hello all,
I have a plastic fuel tank in my beneteau. I had removed the sender and when I replaced could not get a good seal…. Problem with the plastic is that you really can’t tighten the screws down as they will strip. The sender has a black tar like gasket material…… any ideas what this is or recommendations? It leaked after I did this (2 seasons ago) and I sealed the sender with an epoxy type sealant however want to remove and replace the sender as it no longer is working and would love to have a non leaking tank with the ability to get into tank of need be.
Thanks
Greg
Thanks
Greg
