David Wichmann
We developed a diesel leak that kept the bilges mighty smelly, which is a real problem for a liveaboard. After much investigation, etc., we discovered that the plastic (crosslink poly) fuel tank was leaking - on a boat just under two years old!The forward molded in baffle had collapsed and was bulging out the bottom of the tank (which has no supports under it). I find it hard to believe that they would use a material that can't handle the fuel, but we are completely baffled by this event.Does anyone have any idea what could have caused this? Has it happened to anyone else?
