Richard Bryer
As the weather improves and spring gets closer, I am doing some serious thinking about how to add a cleanout port to the fuel tank on my H34. I have looked through the archives thouroghly and it seems there are 2 ways I might make a cover for the opening. The tank is poly and has developed bout 3/8 of a convex dish in the top. It is of course hard to get to and inconvenient to work on.The first would involve either 1 or 2 probably metal ( stainless or aluminum) frames and a rectangle of probably Lexan and preferably clear. I would envision tapping the lower frame and threading 10/32 bolts up from the bottom and installing this frame inside the tank with a gasket ,with the studs facing up and through holes in the tank.On the top ( and outside) of the tank I would put another gasket ( I probably would use some sort of automotive, diesel resistant gasket material like Permatex)then the clear cover then the other frame piece. I would then tighten down with probably acorn nuts with locking inserts. One of the concerns I would have would be that the curvature in the tank top makes it hard to get a good seal- thus the two piece metal frame to draw it flat. Disadvantages in this method- more work cutting the frames and drilling. I would have to cut with a cutting wheel and finish with filing. Also more time down in the tight quarters drilling and making sure holes line up. I am concerned with getting a good seal on the first frame with the curvature of the tank top.Second method is simpler- use a thinner plastic- probably 1/8 or maybe 3/16 and simply screw it down on the outside over the opening - using the same gasket material and SS screws self tapping with washers into smaller dia holes in the tank.This method would have the cover adapt to the curvature of the tank. Probably is not as strong but I think the sale would be betterWhat are your opinions? It looked from the archives that both methodologies had been used. Anyone used a similiar approach and had several years of success or conversly any failures seen?Any information/experience will help before I commit myself by cutting!
