Fuel Tank Cleaning
John M
Has anyone tried to clean the fuel tank ON a 322? There is a lot of gunk in mine and I'm thinking it is time to clean it out, but don't have a clear idea of how to actually do it. Thanks
May 31, 2004
31
Watkins MKII 27 New Bern NC
ME TOO
I too am dealing with this problem. I have researched having someone polish my fuel using a polisher system. The expense for this is causing me to look for other options. I think I have decided to drain the fuel tank out of the drain plug in the bottom, draining the diesel into fuel cans. I am then going to add a substance that I saw at Defender called ALGAE-X® AFC-705 Fuel Catalyst that supposedly kills all algae, bacteria, and fungus. It also claims to break down any crud in the tank so that it can pass through the engine without harm. I am going to buy 3 or 4 extra filters for my Primary Racor filter system and change often during the season. The diesel in my tank currently has been in the tank for over 4 years and although I have had no problems I am experiencing lower power and some smoking. The problem with polishing your fuel aside from the cost is that the baffles in the tank keep any cleaning action provided by reversing the flow from cleaning the whole tank.
John M
Update
Capt. Sid I drained the fuel from the tank using a siphon system that I bought to change the oil. Worked like a champ. The feul that I recently put int he tank was good, the 3 gallons that was still in the tank looked terrible. Now I'm not sure how to proceed, but I'll let you know how things progress. BTW, where did you install the primary filter? I don't have one on my 322 and haven't found a good place to install one. John
