Any suggestions for how to clean a fuel tank? The tank is gasoline, I have an Atomic 4. This spring it was very rough idling so I dismantled and cleaned the carburetor. There was a lot of gunk so I put in a new fuel filter. After a couple of hours of running it was running rough again so I took out the fuel filter and it was full of crud again.
The tank appears to be in excellent condition from the outside. It is 44 years old, made of monel. I'm pretty sure I cannot remove the tank without cutting up a cockpit locker but the top of the tank is easily accessed, including the inlet hose and the cap for the fuel sender. The capacity is 20 gallons and it is about 1/3 full.
