I haven't done this, but was wondering if anyone has tried emptying the tanks, removing the fuel lines from the tank, sealing most of the orifices, and then
applying vacuum to the tank to suck in the sides to make it easier to pull out. A small vacuum pump could be attached to one
of the smaller diesel ports or maybe use a shop vac on the fuel filler hose?
Lots of water added to the bilge might help float the tank up as well.
On my boat, the previous owner cut out the section of sole between the two sole plates, which makes it easier to get the tank out.
The section was backed up and reinstalled with screws.-Tim________________________________
To: "
AlbinVega@yahoogroups.com"
Sent: Wednesday, March 14, 2012 1:59 AM
Subject: Re: [AlbinVega] Fuel Tank Cleaning/Removal
Point one. Boat needs to be out of water as water pressure squeezes in on sides of keel and holds tank.
Remove all fuel from tank, undo all the various pipes (filler,breather fuel supply and return line) you probably won't be able to get at filler tube so undo from deck filler end.
Get some flat packing/parcel tape ( like they put on heavy parcels) , slip a bight of the tape down into the bilge at the front end of the tank and manouvre beneath the foreward end of the tank and lift. The action needed is to tilt the fore end up while pulling the body of the tank foreward. It is not as easy as that unless you are very lucky but I have done it several times until eventually deciding to go for a tank in the port locker.
To:
Sent: Wednesday, 14 March 2012, 3:14
Subject: [AlbinVega] Fuel Tank Cleaning/Removal
I know I saw an article/diagram on how to remove the fuel tank ... but can't locate it again. Any advice/experience w/ removing the fuel tank for cleaning? I'm thinking of this in order to clean the bilge and coat it as well. Also, cleaning in-place? Remove the plate that has the fuel lines connect thru? Thanks ...
Tom
V1690
