Mickey McHugh
I was checking the archives and in July 1999 I had posted the following on HOW and got the two responses below it.To get my 40.5 ready for transport by truck I let my fuel level get near empty. Then while sitting at the Long Beach shipyard dock waiting for the crane, I ran the engine to get a full charge on the batteries and to also empty some additional fuel. After only 20 minutes the engine quit and I checked the fuel filter and it was dry. It seems to be too soon but that’s cool I thought, the tank is definitely empty and when I get to Texas I can fill the tank and find out HOW much it really holds (true capacity in USABLE gallons). Imagine my surprise when I filled the tank and it only took 34 gallons. What gives? It is supposed to hold 40. Until now, I assumed the tank gauge was off when it indicated empty because the dealer had to bend the float to keep in from hanging up on the side of the tank that made it never read below half. I had thought I still had more than 5 gallons when the gauge said I was near empty because when I filled the tank it would only take around 33 gallons or so. I now realize I was very lucky on some of my crossings to Catalina Island and my trip to Mexico that I didn't run out of fuel. I try to always keep a full tank and refuel if I get down to a quarter of a tank when cruising. I can ‘sail’ into a slip or to a fuel dock but that’s NOT being a prudent sailor.---- Response from Patrick Magers Several years ago I ran out of fuel in my 40.5. Upon filling the tank, it took approximately 35 gallons. This incident occurred when the boat was approximately 9 months old and therefore the fuel tank was relatively clean. I sailed into the fuel dock, filled up the tank, bled the system and the engine immediately fired up. I had no problems thereafterIt’s my understanding that the pick up line will not reach the last three or four gallons in the bottom of the tank. Assuming this to be true, my tank is close to the stated capacity. My boat is a 1994 model. ---- Response from Jim Bohart Actually the tank holds closer to 40 Gals. Its usable capacity is a bit less because the pick up tube does not contact the bottom of the tank but is .5 to 1" off the tank floor. If you have an aluminum tank it should be closer to 40 gals than a roto cast tank which has a thicker wall section but the same external dimensions as the al.The pick-up tube is off the floor to prevent it from sucking up water, algae, slime, and dirt. Maybe it would be more accurate to state usable capacity rather than the actual dimensions.Both responses confirmed what I thought. Well, I thanked everyone for their comments and said I would plan on using 35 gallons as available capacity and that I was thinking about a second tank.NOW in 2002, I still have the same tank and gauge but use jerry cans for extra fuel during our cruising. New questions – What should I have 5 gallons of fuel sitting in the bottom of my tank that I can not use? Sure, I too do not want to suck up water, algae, slime, and dirt but isn’t that why I have a 10 micron Racor. AND to think I have to have 5 gallons of water, algae, slime, and dirt in the bottom of my tank before the Racor even sees it.Both of these thoughts tend to bother me just a little bit. Does it make sense to lower the fuel pickup tube closer to the bottom of the tank to get that additional fuel? PLUS, I just installed a generator with its own Racor from the second pickup in the fuel tank. What if that pickup was lower so if I had a problem with fuel I would know about it when I was running the generator? PLUS, with cross-connect valves, I could switch to the generator's Racor if I got too low on fuel while using the higher engine fuel pickup tube. It should be enough to allow me to motor into the fuel dock.What do you think?
