Tank construction
Several years ago i was employed in the electronic sheet metal trade.Being a job shop we often took on fuel and water tanks.Also for short period worked for a tank supplier to Hunter. Most tanks are made the same way,two u shaped formed up pieces,bottom one is bottom plus two sides.to this is tack welded the baffle.Other u 4is inverted over this and contains top plus two ends,no way to tack baffle to this when in place so there will be no sign of baffle on top surface when done. I said most as there are exceptions when the wrapper[top, bottom, both sides] are one piece and two ends and baffle are added.that would show baffle on top.This type wrapper is harder to form so rarely used.
