35.5 fuel tank
There may be a screen on the pick up tube inside the fuel tank. A recent call to Hunter Tech confirmed that pickup tube screens were used during at least part of the Legend series production run. At some point Hunter discontinued the use of screens on the pickup tube because of owner complaints about clogging. IF your boat has the screen - being a '95 it most likely does not - it is prone to clogging by the gunk growing and accumulating inside the tank. The solution is to remove the pickup tube from the tank and un-install the screen letting your racor do the filtering job - not an easy task. First the bands, made of either fiber or stainless steel, holding the tank in place must be cut allowing you to slide the tank to port or starboard so that you can work on it, after you siphon off the fuel inside the tank. But dont pull the old bands through as they can be used to string the new ones in place. Remove the pickup tube, take the screen off, reinstall the pickup tube, replace the tank, re-thread new hold down straps, fill tank, bleed engine if necessary, go sailing.If your tank is foul there is a simpler procedure. Using a siphon, or fuel safe transfer pump (I use the TopSider oil changer sold at West Marine with a 2.5' long copper tube added to the plastic siphon tube) you can siphon off the fuel - hopefully the tank is near empty - and suck out the gunk with the fuel by inserting the copper into the tank through the fuel guage hole and continually moving it around the seams of the bottom of the tank. You can see the stuff come out through the clear plastic tubing. The fuel can then be re-filtered and put back into the tank or you can use fresh fuel. However, you must now get rid of any microbes that are attached to the walls of the tank. This can be accomplished by purchasing the fuel polishing kit sold at West Marine and follow the directions for your size tank, which would use about 1/4 of the product. Fill the tank completely so the biocide comes in contact with all the tank walls and do some motoring to mix it up and get the stuff all through the system.If your tank is not foul and you want to prevent problems you must 1) keep any water out of your tank (easier said then done), 2) filter your fuel at every fill up using a good quality filter, 3) Use Biopor, but remember, less is better then more, 4)drain the tank for winter lay-up instead of topping it off (condensation is not so much of a problem with a poly tank)By the way, Hunter has gone back to using pickup tube screens because owners complain about clogging fuel filters. I can't believe that anyone would want to deal with a clogged pickup tube screen instead of a clogged filter, but to each his own.Sorry for such a lengthy response, good luck.
