I have a very slow leek in my fuel tank, has anyone had any experience in removing the tank.At this time the only way I can see to get the tank out is by cutting a access hole in the aft berth bulkhead .
You are 100% correct. The only way to remove the tank is to cut a hole in the wood bulkhead located in the rear cabin. Also I found that the original tank builder located in Florida is not to sure about which tank goes in your boat. I ended up purchasing an 18 Gallon below deck plastic tank from West Marine.
