G
Greg
I just experienced running out of diesel. Not pretty. I am in the process of changing all my filters. One is on back order. I have searched the manual and diagrams that are posted on the Morgan 41 site trying to find what they want when you switch from your main tank. What I did (which didn't work) was leave one handle in the engine room on to the main tank and switched the other to the spare tank thinking that would let the spare tank drain into the main tank. With no luck, as stated earlier I still ran out of go juice.I see that they recommend that you use a stick to check how much fuel you have. What do you use to check the main tank? Fuel line has too many bends.I have a 1983 OI ketch. Thanks Greg
