Sid Sytsma
Hi GordonI have several related questions on the fuel system for the Yanmar 3JH2BE engine in my 2000 Catalina 380.(1) What fuel element should be in the RACOR500 filter, 2 micron, 10 micron, or 30 micron?(2) The engine has 60 hrs on it. Should either the RACOR primary filter or the secondary filter be changed (given a new engine, tank, et al)?(3) Could you explain in simple terms how the fuel gets pumped from the tank, through the primary filter, secondary filter, etc., please? Are there two pumps? When changing the RACOR filter element, how does one bleed the air from the RACOR, or doesn't that have to be done? I understand how to bleed the secondary filter with the little flipper lever on the injector pump.The 3JH2BE Owners Manual, and the Service Manual (that I got from Diesel Direct!) are not clear to me on these points. Many thanksSid SytsmaPS Your keel guy [at Torresens] did a beautiful job installing the keel on my 380 this spring...
