Fuel shut off
36
Hunter 380 Rock Hall, MD
We were changing the Rancor fuel filter for the first time last weekend and could not determine where or if our 1999 Hunter 380 has a fuel shut off valve. Can anyone help me out? Thanks
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
It should be mounted directly on top of the fuel tank that the fuel supply line feeds from.
May 24, 2004
7,164
CC 30 South Florida
Follow the fuel supply line back to tank and you will find it. To get to ours we have to remove a wood panel in the stern berth. Because of that I have gotten quite adept at the quick change. Open the drain valve on the Racor and let the water/fuel spill through a hose into a container while simultaneously opening the top of the filter body to pull out the canister. Re-insert a new one close it up and shut the valve off as by then any water has been pushed out.
rfrye1
Jun 15, 2004
589
Hunter H376 San Diego
I have a H376 (same setup). Yes the fuel shut-off is buried under all the stuff in the starboard aft locker. And its a pain to get to. I have installed an in-line fuel shut-off valve in the engine compartment (between the fuel tank and primary filter). It makes filter changes SO much easier. Of course double clamp and buy quality valves. Happy Sailing. Bob
Jan 12, 2010
36
Thanks guys!! Great suggestion, I'll have to add the in-line fuel shut-off valve to my list........
