Interested to know / hear comments re rubber primer bulb located beside fuel tank on 2004 Hunter 33. Engine vacuum continually causes bulb to deflate causing fuel restriction then obvious fuel starvation issue. Question is is as engine Yanmar 3YM30 has primer level / pump on engine is rubber priming bulb necessary? Have only previously seen one on outboard engines. Initial response is to replace total fuel line to remove another potential weak spot in the system.
