Maybe no screen
There may be no screen, there was none on my H34, 1984However, after you break open the fuel system, all air needs to be purged from the system.If you are only removing the fuel pick up, then you can get away with bleeding the secondary filter, the one attached to the left front of the engine.To do this, loosten the screw on the top, and activate the lever on the fuel pump, when only fuel comes out, you are done. If you have not run the engine out of fuel. there should be no need to bleed the injectors.Good luck,John, sv 50-50
