I have 20’ of this line. I purchased it through McMaster Carr. The SAE-30R7-KX. I was going to use it to replace where ever it will fit. I googled the SAE# and found this:
For conveying fuel in automobiles, trucks, buses, etc.. SAE 30R7 type B USCG approved fuel line hose. Not designed for marine use with alcohol blended fuels.
Application:
Tube - Black Nitrile
Reinforcement - Spiral synthetic cord.
Cover - Black synthetic, Nitrile / PVC blend restistant to oil, grease and ozone.
Branding - Size SAE 30R7-KX date, Made in U.S.A.
Low-Pressure SAE Fuel Hose
- Use with diesel fuel and gasoline with up to 15% ethanol
- Temperature Range: -29° to +257° F
- Color: Black
- Hose: Buna-N (nitrile) rubber
- Cover: Blended Buna-N rubber/PVC
- Reinforcement: Polyester yarn spiral
Designed for inline connecting of fuel lines, this hose meets SAE 30R7 standards. Hose interior is smooth for unrestricted flow. Can be used indoors and out. Vacuum rating is 24” Hg @ 72° F.
To Order: Please order in 5-ft. increments up to the full coil length of 100 feet.
Click
here for information about chemical compatibility.
