Finishing replacing all the engine hoses, I am at the fuel lines now. I am relocating the racor fuel filter and fixing the tank shut off valve (frozen), I have a 3/8 hose with flared fittings (AN fittings?) from the petcock to the Racor filter and a 1/4 barb fitting with 1/4 hose from the Racor filter to the pump. The 3/8 line may be original. It has many rub marks from the stringer and is cracked. I have plenty of new 1/4 marine fuel hose. Can I run straight 1/4 from the petcock to the filter and then to the engine. I assume it will have enough flow since I already had that size from the filter to the pump. Any problems with my solution?
Jose
Jose
