I have been unable to find through normal channels a fuel line for #2 cylinder on a Yanmar 2QM15. Can anyone help me locate one so I don't have to have one custom made?Thanks,Bob
Are you refering to the line from fuel pump to filter,line topump, return lines or injector lines. these lines should still be avail through Yanmar dealer. If not contact me. I know of a couple of dealers on the east coast that might have used ones. also depending on the lines needed i believe some lines on the 2gm20 are the same.
Yanmar should still have this part. if it's not listed as still being available. check out the injector lines on the 2GM 16? or 20? the engines actually have some parts that are common to both engines. If no lucl there check out mastry marine in fla. I had bought some used parts from them in the past.for my 2qm15. another place to check would be the yanmar dealer in portland ,maine i don't remember the name of the dealer though. good luck.
