Hope that all of you are in the water, sailing and enjoying the summer. I, unfortunately have not been able to get out of the dock due to a myriad of problems, domino effect.
After waiting for a repair of the furling that was damaged when the boat was put in the water I discovered that my lift pump was not functioning. Apparently the power wire was torn out of the unit. I replaced it with a diesel lift pump (12 volt) that I purchased from an automotive supply house. The original pump was available only on the net and I wanted to get it fixed "now". I installed it and it appears to be working well.
The question is whether or not I can rely on this $60 pump or should I order an original replacement for double the price?
