After a five hour motor from Rock Hall past St. Michael's on the Miles River, we anchored behind what is known as Long Pt. Island at about 1600. I had checked the bilge before we left and found an inch of rain water that I assumed came down the mast earlier in the week. I did not check it when we arrived at our anchorage. Soon after arrival, our entourage of eight was picked up by a friend and taken to a family barbecue at a spectacular home overlooking the Miles River. We made our way back to the boat at about 2330 blanketed by a star filled sky. After saying goodbye to our host who had given us a ride back to the boat, six of the crew settled in with a nightcap and constellation identifications when one of the crew mentioned casually, "I smell something kind of like gas." This of course sent me into a search for the source of the smell which I easily found. There was six gallons of diesel fuel in the bilge. I sent everyone above and ripped the boat apart to determine the source to which I could not find. The leak seemed to have stopped with the fuel tank showing 1/2 full. We left with 3/4 full. The needle would normally not show much movement after a 5 hour motor.
The next morning our host returned with two contained to which we pumped the fuel. After checking all visible sources for the leak power on and off. We decided to motor back to Rock Hall and check things along the way. We made it back without any additional fuel in the bilge and the fuel tank read minimal change after a four hour motor. We had wind for about an hour.
I checked the boat again yesterday to find no change in the bilge. I inspected the engine again and found the area around the fuel pump to be wet but when I ran the engine again, I did not see any change. It did not seem like it was leaking six gallons.
I can see about 3/4th of the tank. There are no visible signs of leaking. If the tank was leaking why would only 1/4 leak out and stop if it was from the bottom?
Any ideas on where this leak may be would be very welcome.
