fuel Gauge
4
Hunter 1993 Hunter 30 Tolchester, MD
:bang: I have a 1993 Hunter 30, and I am tired of standing on my head to read the "Lawn Mower" type fuel gauge in the top of the tank. Does anyone know if there is an up grade to this problem ? I looking to find a fuel tank float mechanism that works with a remote fuel gauge that I can mount in the cockpit next to the engine controls.
Thanks
Feb 2, 2006
470
Hunter Legend 35 Kingston
The gauge on my 1987 legend 35 sounds similar to yours. Mine is a float based thing on the top of the fuel tank that also has a place to attach a remote gauge. I did a test on
mine and it seemed to conform to the standard resistance reading for the amount of fuel it had in it, so I'm pretty sure I can wire in a off the shelf fuel gauge.
Chris
Jul 23, 2006
12
Hunter 28.5 Lake Lanier GA
LarryMac... I have a Moeller sending unit (new) I'll sell you for ten bucks and a couple of dollars for shipping. I bought a new Moeller 13 gallon tank and a Moeller diesel sending unit. The sending unit arm is for a tank depth of 12" to 21" (their web site is wrong). Unfortunately, the Moeller 13 gallon tank is only 10" deep. I switched out the sending unit plate on the tank with the plate on diesel sending unit because I needed the diesel return. Check out www.moellermarine.com, and let me know via e-mail if this is something you could use. When looking at the sending unit/gauge it's the round metal part that I swapped out.
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
Instead of adapting an electrical sensor which may or may not provide accurate readings for your tank consider installing an hour meter. It will not only facilitate fairly accurate readings of fuel consumption and availability but will also help with engine maintenance requirements. In order to calculate fuel consumption and availability in tank all you need to know is the burn rate of the engine in hours and the size of the tank in gallons. A 2gm diesel burns under 1/2 gallon an hour on the average and if you have an 18 gallon tank you may safely surmise that your tank holds fuel for 36 hours. Fuel holding and usable fuel are two different things as the engine will start to suck air and quit before the tank can run dry. For navigation range purposes I would use 30 hours leaving 3 gallons in reserve. Once you have all this info all you need is to create a log and jot down the number of hours on the meter every time you fill up. Let's say you are going sailing one day and you want to know how much fuel you got left , take a reading on your meter and subtract the number on the log to see how many hours the engine has ran since last fill up. Lets say 8 hours so you know you have only used 4 gallons and hold 14 gallons in your tank of which 11 should be usable for 22 hours. Once you do the calculations they become easy and second nature. I have not found a more accurate and reliable fuel gauge than keeping tabs on your consumption. We took a trip recently on an h34 which had no gauge nor hour meter. We just made a point of keeping in our heads the motor run times per leg and after 10 days and some 500 nm we had the burn rate pretty pinned down at 0.65 gph. Whichever way you decide to go it is always good to know the burn rate of your engine and boat. You need not factor in currents, wind nor condition of hull as it is a simple formula, fuel used in gallons divided by time in hours. I don't break it down by engine RPMs as all I need is an average figure accordying to my motoring style, 95% of it is at cruising RPMs anyways.
RAD88
Dec 15, 2008
163
Hunter 30 Glen Cove, NY
Actually a gauge would be more accurate and much easier to use. I can not imagine trying to remember how many fractions of hours I have used the engine and also log this information. This is also why they install fuel gauges in cars. They are very easy to install on a boat and very reliable.
I admit it could be helpful to know how much fuel your engine uses so as not to run out on a long trip. A 5 gal jerry can of diesel goes a long way in the event of a dry tank. To sum up there is a comfort to looking a the fuel gauge and knowing how much is left.
Mar 31, 2009
4
That sounds interesting, I'll have to check mine and see if it has the adaptor for a remote reading.
Thanks
