Fuel gauge Beneteau 423
NYSail
Jan 6, 2006
3,143
Beneteau 423 Mt. Sinai, NY
Hello all
In conversations with the PO, he said that the electric fuel gauge was very unreliable and that he based his fuel level on his use..... He said he has had the sender replaced and still not reliable. He is not too sure if he filled the tank completely at the end of season, however the gauge reads full. I guess I have to open the tank to visually see where the fuel is or is there another way?? I have not exposed the fuel tank yet so not sure if there is a sight glass on the tank..... Is this a common problem or just a couple bad senders?
Thanks!
May 20, 2016
3,015
I've worked on a bunch is old autos. Fuel gauge issues are often bad grounds. Especially if the sensor was replaced
Gunni
Mar 16, 2010
5,937
The sender units are cheap crap. MaineSail has a nice write-up on several improved fuel sender units at his website including one with a sight-glass backup. I replaced my sender last year but did not cut and calibrate it, so it is grossly inaccurate. The old one was very accurate while it worked. With the new sender when I am at empty I still have 10 gallons of fuel so I have one known data point.
NYSail
Jan 6, 2006
3,143
Thanks for the great responses. Engine is a yanmar 4jh4e..... figure burn rates close to gallon / hr depending on rpm's. Will check mainesails site and will open up and see what's up with the take. Will check the ground.
