Fuel Filter
C
Capt JON
Have a 30 hunter 79,need to change my fuel filter because i am not getting full power from engine.I like a step by step drscription.(ysm 12 yanmar) Thanks
Feb 17, 2004
268
Hunter 30_74-83 Lower Salford, PA / Tolchester,MD marina
Primary and secondary
You should have two filters. The in-line primary coming from your fuel tank. Depending on what you have- this could be the original where you open the top and remove the cartridge or a upgrade replacement with a raycor spin-on. The secondary filter is behind the water pump. 1. Turn off the valve from the fuel tank. 2. Determine primary filter and unscrew. Remove and replace element. Wipe inside with clean towel leaving no residue or fibers from towel. Refill with fresh diesel and replace. 3. Remove side of cabinet to gain access to engine compartment. Unscrew large ring above the secondary filter behind the water pump. Pull out filter and wipe clean. replace the element. make sure this is inserted in the correct direction. closed end goes down. Replace o-ring, fill with fresh diesel and replace by screwing ring back onto filter case. 4. Reopen fuel valve 5. at about 10:00 o'clock on the engine face is a small bleed screw- octagonal head with phillips thread. Slowly open this screw. You will know its the correct screw if you back it out you will see a small hole. expose this hole. 6. You will see a lever below the secondary filter. pump with your index finger untill a steady stream of diesel pumps out the screw. 7. Screw bleed screw back into engine and wipe up oil. 8. Check belts tension while you are here. 9. That's about it. Remember to re-fill filters or you will never bleed system.
Bill O'Donovan
10.
I would add to Ian's excellent list... 10. Use a West System plastic syringe to top off the fuel filter cannisters with fuel, and thus you may not have to bleed at all.
Sailing Cop
Excellent Idea
Jonny HAs a Great Idea...Look HIM Up..I can give u STEP by STEP description ALSO as to what to do....Good Luck to You....Lot of work and Patience........so U have to " Stay Loose" and Take a Lot of Good Mechanic Advice......lol
C
CAPT JON
Thanks for the tip
You seem to know your stuff,espically when animals attack,lol
Sailing Cop
CANT Imagine How an ANIMAL Crawled In there
OMG ...SHE" was a Vicious Little Devil too.....Had a very " LOUD CONSTANT GROWL" and survived the " RIDE " lol.... AMAZING !!
Sailing Cop
Just Wondering
Capt Jon.........was wondering How You Made out with putting the New Filter In.Does it turn over "Strong"?....You are A " real Mr Fixit...and I Know JR. Helped a Great Deal......lol
