Fuel problem
Since you have replaced the primary filter, other issues could be the filter at the engine, pickup tube in the fuel tank, fuel pump or fuel lines. Remove the pickup tube and check for blockage, I did not have a screen in the tube. Remove fuel lines and blow through to see if there is blockage there. Is the fuel pump working? You did not mention which engine or the age of your C30. Earlier models had the primary filter after the pump, should be between the tank and pump. This can cause the pump to get clogged with whatever is in the fuel. After everything is checked out you will need to bleed the fuel system. The scondary fuel filter screws on like the oil filter, simple change, assuming a M25 deisel.
I had a stalling issue a couple of months ago, low on fuel and a dirty primary filter. I removed last years fuel and replaced with new, checked all lines, replaced primary fuel element, cleaned primary pump, rerouted fuel lines from tank to filter to pump and replaced the pump.
