Raycor Model?
Pete,The OEM filter on our '86 Yanmar 2GM20F was a Fram, so it's likely that a Raycor could be a newer replacement, some of which have a priming pump on them.I'd Google Raycor and check the model #. Basicaly, first close the fuel valve on the tank to keep from draining the fuel in the line back into the tank. If it's a spin-on cartridge type such as a 220 serries, use a rubber strap wrench to remove the cartridge with its plastic or metal bowl attached. Empty the fuel into a pan, then separate the bowl from the cartridge with a second strap wrench ($10.00 for the pair from Sears). Install the new canister to the plastic or metal bowl hand tight with the new gasket provided; use a funnel to fill the components with fresh diesel fuel from the top; screw the components back onto the housing. Open the fuel valve on the top of the tank,open the bleed screw on top and push the priming pump button a couple times till fuel has completely filled the top of the filter and comes out the bleed screw as you close the bleed screw. I keep a small sauce pan or pie tin under the filter while I do this.Now remove the filter canister on the front of the engine by carefully tapping the top ring with a wide bladed screwdriver; unscrew thr ring and remove the aluminum bowl and old filter. Clean and re-fill the bowl with fresh fuel about 3/4's full; attach the top end of the new paper filter element to the housing and open one bleed screw. Instal an new 'O' ring and lift the partially filled bowl slowly up around the filter cartridge and reinstal and tighten the outer ring. Tap it a couple times with the flat screw driver blade to tighten. Now with the bleed screw still open follow the fuel line back from the filter back on the starboard side of the engine to the manual fuel pump. Work the pump lever down a couple full strokes till only fuel and no air bubbles comes out the filter's bleed screw as you tighten that screw with a new washer in place. Again a small sauce pan or raggs should be used to catch the fuel that squirts out of the bleed screw and runs down the housing.You should now be able to start the engine without needing to bleed the high pressure side. If you had removed or disconnected any fuel lines, particularly the metal lines with banjo fittings and copper washers, you would need to replace those washers. Bleeding the high pressure side at the injectors requires more than a do-it-yourself knowledge of the proceedure - I suggest you have someone knowledgeable in diesel engines show you how the first time.
