I would like to be able to fill a 6 gallon fuel tank from outside my 26S. The portable tank is kept in the lazerette. With all the other stuff packed in there its a pain to unpack, unplug the engine fuel supply line, fill and then repack it all. Ideally, I would like to find a kit that would provide a vented cap mounted on the coaming and with a flexible hose and screw on connector to my Honda tank. The screw-on connector would replace the existing cap with float gague and vent screw combo. It might have to go to a permanent tank, but I'd like to avoid that expense if possible.
