Go With the Flow
Don't know when this week you're going but since there aren't many more days left I'm assuming it would be around Friday or Saturday. The currents aren't very cooperative.Looking at the currents for, say, Saturday, it ebbs in Puget Sound (Bush Point) From 6:30 AM until 1 PM. If you depart Seattle between these times you can ride the ebb north. Try to get past Edmonds to, say, abeam Possession Point on Whidby (near Norma Beach or Meadowdale) by 1 PM because that's when it starts to flood again and it's a small flood. Stay on the Everett side of the channel for awhile to avoid any back-eddies on Whidby. Distance about 12 miles from Shilshole so leave Shilshole by, say, 11AM.Ride the flood north toward LaConner but it's a short flood. The ebb at Bush Point starts at 3:30 PM so that doesn't give much time - about 2-1/2 hours without a correction factor. Langley is about 14 miles so you could get past Langley. Oak Harbor is about 30 miles so even though you started out with the current with you by the time you're past Langely you're going to be headed again and big time (11.5 feet at Seattle). Sunset for Saturday is 4:44 and dark at 5:57.For Sunday - this is terrible - it ebbs until 1PM so you'll have the current on the nose until you can get past La Conner. You'll be getting to La Conner just about the time it starts to flood again so you'll have the current on the nose all the way through the Swinomish Channel. Once you get to Anacortes, fuel up, then head north again the ebb will start and - you got it, headed again! Arrrgh!Plan B is to bite the bullet and go via Port Townsend. Ride the ebb (2 kts) as long as you can out of Seattle and going up the main channel once it floods try to pick up the back eddies as much as you can: Skunk Bay (below Foulweather Bluff) and all the bays along Indian Island. Stay overnight at Port Townsend.Cross the Strait in the morning and try to get as far as, say, Smith Island by 1 PM (slack at Bush Point is at 1:30 but it'll be a bit different near Smith Island but hopefully not too much). Ride the flood until a bit after 4 PM up Rosario and then get headed after that (another 11-ft tide).Also, there's a small area north of Smith Island where the water can get really lumpy.With the short days we have it looks like you might need more than two days.Weather forcast for the next day at Poulsbo:Wed 12PM: 43F (Wind Chill 37F) Wind SW 12 RainWed 2PM: 43F (Wind Chill 36F) Wind SW 13 RainWed 4PM: 43F (Wind Chill 36F) Wind S 13 RainWed 6PM: 42F (Wind Chill 35F) Wind S 12 RainWed 5PM: 43F (Wind Chill 36F) Wind S 13 RainWed 11PM: 42F (Wind Chill 38F) Wind S 7 Light rainThu 5AM: 41F Wind S 2 RainThu 11AM: 41F Wind S 1 RainThu 5PM: 42F (Wind Chill 38F) Wind S 7 Heavy rainThu 11PM: 42F (Wind Chill 36F) Wind S 11 RainThere's nothing so bad that there isn't some good - at least this way I don't have to wash the bird poop off the deck.For plastic fuel tanks I'd recommend making sure you get something with UV inhibitors in the plastic otherwise they'll fade. Blitz has some with UV inhibitors.Good luck on your trip! Oh yes - and look at all the southerlies!
