Fuel Consumption Rate
Tim, Was going to ask why you needed the rate in liters, then saw you're in MelVVorne; caught the ferry from there to Tassie when heading to Strahn to work on an Abalone boat.1) Very difficult to ascertain exact consumtion rate, carry extra fuel, and never get below 1/3 tank in a diesl as you hit a wave, fuel gets airborne, and you suck air!2) John Vigors book, lotta skippers use, has one gallon per hr for each 18 H.P. for diesel, one gal per hr for each 10 H.P. for petrol.Assume an engine at cruising speed uses 2/3 of the available H.P. to complicate it more, most diesels have two rated H.P. outputs, a higher one at max RPM for one hr.These are GENERAL guidelines, all engines, trans, hulls, props and conditions will play havoc with calculations.Fill all the way up the neck without air pocket, log EVERYTING then refill exactly the same, log EVERYTHING each trip; then do the division, and above all carry more fuel than you 'think' you'll need.
